Activity Forums DaVinci Resolve No users in Resolve…
  • No users in Resolve…
    Posted by Kent Kumpula on September 13, 2011 at 6:29 am
    Hi guys.
    I just installed Resolve on one of our macpro computers, and after tons of struggle and a reinstall I found out that it was actually two of my new GTX 285 cards that are no good. They crash the computer whenever I try to run anything that is using CUDA. Great.
    Well anyway, I threw in another GTX 285 card that I know works (I have had it in another macpro), and now I can run Resolve. But another problem arises…
    There are no users in Resolve. No guest and no admin, and if I try to hit “+”, trying to add a user, nothing happends. I tried to create a new database, but I don´t have any users in this database either.
    Anyone else had problems with no users in Resolve?
    Kent Kumpula replied 14 years, 11 months ago 3 Members · 3 Replies
  • Sascha Haber
    September 13, 2011 at 8:34 am
    Yes and there is a solution for it .
    A fix for this requires a few command for you to type on the terminal. This will uninstall the database, so the next install of Resolve will install it properly.
    1) Stop the server
    sudo /sbin/SystemStarter stop postgresql-8.4
    2) Remove menu shortcuts:
    sudo rm -rf /Applications/PostgreSQL 8.4
    3) Remove the ini file
    sudo rm -rf /etc/postgres-reg.ini
    4) Removing Startup Items
    sudo rm -rf /Library/StartupItems/postgresql-8.4
    5) Remove the data and installed files
    sudo rm -rf /Library/PostgreSQL/8.4
    6) Delete the user postgres
    sudo dscl . delete /users/postgres
    Now, re-install Resolve, reboot, and then start Resolve.
    Hope this helps!
    Regards,
    Rohit
    Keep in mind, this will remove your DB completely.
    I suggest moving away from the local DB and using a dedicated machine for it.
    Works very very here.
    A slice of color…
    DaVinci 8.0.1 OSX 10.7
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB eSata 6TB
    GTX 470 / GT 120
    Extreme 3D+ WAVE
    http://www.saschahaber.com
  • Thomas Pohl
    September 13, 2011 at 12:22 pm
    Are you sure that your MacPro is compatible with the GTX 285? Your Mac must be Vers. 3.1
    Cheers
    Thomas.
    https://www.footage-online.de – RED footage and more available in HD, SD and RED RAW R3D
  • Kent Kumpula
    September 13, 2011 at 12:56 pm
    Thanks guys, the macpro is from this year, so yep, it is compatible. And I tried with another GTX 285, and it works just fine. These are PC-flashed cards purchased from Ebay, sadly I had bad luck and got bad-flashed cards or something.
    I have contacted the seller, haven´t received any reply yet but he is big and seems honest so it will be interesting to see how we solve this.
