Activity Forums Adobe After Effects No touching
  • No touching
    Posted by Eddy Rose on June 11, 2011 at 5:48 am
    is there any way to ensure my particular particles won’t overlap each other when being emitted from a flat emitter? Tried the box emitter but it looks waaaay too organized.
    Graham Macfarlane replied 15 years, 3 months ago 2 Members · 3 Replies
  • Graham Macfarlane
    June 11, 2011 at 10:51 am
    Try setting emitter type to Point and Direction to disc. Then if your velocity random % = 0 you might get some particles close to each other but you shouldn’t get any particles passing over each other.
    Beyond this you might want to try something like particle flow in 3D studio max to get more control.
    Graham Macfarlane
    3D animator and VFX specialist
    London UK
  • Eddy Rose
    June 11, 2011 at 5:51 pm
    …I totally forgot to mention that the particles can’t be moving either. they’re just supposed to pop up and disappear. Also I meant to say it’s the grid emitter that looks to organized. The box emitter is the one I’me using,, if I make the x,y dimensions really big they don’t overlap as much.
    Sorry about that. Yeesh, I really shouldn’t ask questions to a forum at 2AM, being sleepy makes me retarded.
    Here’s a screen shot of what I was going for,, just to clarify. The +’s on the ceiling and wall are my particles.
    https://imgur.com/4Jz9o.png
    View post on imgur.com
  • Graham Macfarlane
    June 11, 2011 at 7:36 pm
    In that case:
    Have you tried using the grid emitter whilst adding turbulance to break up the uniform positioning?
    Graham Macfarlane
    London UK
