Activity Forums Adobe Premiere Pro No timecode on clips
  • No timecode on clips
    Posted by Scott Rucci on August 21, 2014 at 9:57 pm
    Hi. Wondering if anyone has experienced this. Using cc 2014 on Mac Pro 10.7.5. I bring in mts files from a Sony FS700, recorded to an sd card and the media start for every clip is all zeros. I am simultaneously recording this footage to a Convergent Design Odyssey 7q and the timecode from it is normal for the same clips. When I return the FS700 SD card to the camera, the timecode is in fact on the clips. I can find no metadata display settings to resolve this. Ideas?
    Scott Rucci
    Rucci Productions
    ruccipro.com
    Peter Garaway replied 12 years ago 3 Members · 5 Replies
  • Al Levine
    August 21, 2014 at 11:10 pm
    You shouldn’t be running CC 2014 on 10.7.5… minimum system requirement is Mac OS X v10.8. I’ve heard of a ton of problems with people trying to run 2014 on 10.7…
    This might not solve your issue but will definitely save you from a headache down the line…
  • Peter Garaway
    August 22, 2014 at 12:46 am
    Hi Scott,
    I would be interested in getting a small sample file if you have one. We should be picking it up. You can upload to your CC account or another hosting site.
    Peter Garaway
    Adobe
    Premiere Pro
  • Scott Rucci
    August 22, 2014 at 9:02 pm
    Thanks, we can try updating the OS again. Last time it caused some problems so we reverted and never tried again. So we can give it another shot. We are experiencing some weirdnesses, maybe that will help.
    Scott Rucci
    Rucci Productions
    ruccipro.com
  • Scott Rucci
    August 22, 2014 at 9:49 pm
    Thanks for your help Peter. Here’s one of the test clips.
    https://dl.dropboxusercontent.com/u/2370062/00020.zip
    Timecode for this shot starts at approximately 1:00:30:00. If you listen to the audio I am speaking what the timecode should be.
    Here is a screen shot from Premiere showing the clips from both recorders (camera and Odyssey).
    https://dl.dropboxusercontent.com/u/2370062/Screenshot%20timecode.png
    In the screen shot the third shot in the list is the one linked above.
    If you need a copy of the matching ProRes file created by the Odyssey 7Q let me know.
    Scott Rucci
    Rucci Productions
    ruccipro.com
  • Peter Garaway
    August 26, 2014 at 11:37 pm
    Thanks for the files Scott. We’re reviewing them now. Ill let you know what we find out.
    Best,
    Peter Garaway
    Adobe
    Premiere Pro
