Activity › Forums › Creative Community Conversations › No timecode from Compressor template in FCPX
Lars Hogeus replied 9 years, 7 months ago 5 Members · 13 Replies
Francois Jean
February 11, 2017 at 6:52 amMacbook retina 2013 , el capitan 10.11.6 ( this is my reference clean machine) seldom use it but for testing
I daily work on my iMac updated el capitan 10.11.6 both latest pro apps … I get no correct TC burn from Compressor 4.3.1
Tested with
Canon C300 MXF source
Editready Sony PMW-F3 converted
Quicktime movie with time code track added
Sony F55 MXF original footageall source material TC are correctly read by FCPX and Davinci 12.5.4
Definitively a BUG in compressori 4.3.1
I can reproduce same problems.
I also tried both droplets , then did a direct setting adding a TC generator and get the same wrong results .
I did send a feedbackFRANCOIS
Ronny Courtens
February 11, 2017 at 9:31 amConfirmed. My initial tests were with Compressor 4.3. Does not work in 4.3.1
– Ronny
Lars Hogeus
February 12, 2017 at 9:58 pmThank you very much everybody for taking time to look at this!
Is there a way to go back and re-install Compressor 4.3?
Lars
