Activity Forums Adobe After Effects No Textured Polygon in Trapcode Particular menu
  • No Textured Polygon in Trapcode Particular menu
    Posted by Andrew Fed on August 30, 2021 at 3:05 pm
    Hi, guys, I’m at a loss. Neither the Internet nor Red giant forums know a solution to my problem. RG support’s keeping silent. And I need a solution about right now ((
    I’ve a Trapcode Particular 15 installed with my AE 2021. It works fine. So I need to make comp with question marks emitting in 3d space. For this I created a text layer with a single “?” and a black solid with a Particular effect on it. The rest is easy according to Youtube – you go to particles menu of this effect and select Textured Polygon then the ?-layer. The problem is that there’s no textured polygon or others seen on Youtube. See what I have in the screenshot below. So what shal I do?
    Andrew Fed replied 5 years ago 1 Member · 0 Replies
  • 0 Replies
