Activity Forums Boris FX No Text Window in Single Monitor Setups
  • No Text Window in Single Monitor Setups
    Posted by Matt Sowder on June 6, 2006 at 7:09 pm
    Recently had this problem on Media100 using Grafiti 3.0. Went down to one monitor… no text window… Now using ver 4 on FCP and the same thing… How do you get the Text window visible in a one monitor set up It’s an apple cinema 23″ so more than two is A LOT
    Matt Sowder
    Fiddler’s Ridge Productions
    Mark replied 20 years, 2 months ago 2 Members · 1 Reply
  • Mark
    June 6, 2006 at 8:55 pm
    This happens, it just sometimes seems to dissapear…usually it is off the side of the screen. Anyway, try in the window menu, there is a snap all home…this will reset window positions. Also, make sure in the window menu that text window is checked.
    If neither of these 2 help, you may have to delete your preferences to Red.
    Mark
