Activity › Forums › AJA Video Systems › No sound SP Betacam to Kona LSe via Digibeta
  • No sound SP Betacam to Kona LSe via Digibeta
    Posted by Amit Ghildiyal on August 26, 2009 at 8:04 pm
    i have attached video ref cables from the betacam to the digibeta which is connected to the LSe card. I have the video feed and am able to control the Betacam deck through FCP but even after trying different combination of connecting the sound output from the betacam to the digibeta input, I have been unable to get sound. On FCP, the capute preset is
    NTSC,
    AJA KONA LS NTSC 8 bit to DV
    sound iv adjusted to 16-bit as i read in the manuel that Kona prefers 16-bit.
    PREVIEW SOUND IS CHECKED IN THE CAPTURE WINDOW
    Audio playback is through the Kona card
    and iv tried attaching the sound cable directly from the betacam to the breakout cable.
    Still no luck.
    Mario Herrera replied 16 years, 10 months ago 4 Members · 4 Replies
  • Bob Zelin
    August 26, 2009 at 9:50 pm
    open AJA Control Panel – INPUT tab. Choose ANALOG audio.
    Bob Zelin
  • Arnie Schlissel
    August 27, 2009 at 2:39 pm
    How are you patching your audio from the Mac into the SP deck?
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Amit Ghildiyal
    August 27, 2009 at 5:02 pm
    It is through the digibeta deck. i GOT IT WORKING NOW THANKS i HAD TO MATCH EVERYTHING TO ANALOG. Also can I do this directy? (attach the betacam sp to the kona LSe.) To edit to tape in the Betacam SP? Where can I learn more about this?
  • Mario Herrera
    November 18, 2009 at 12:09 am
    How can I connect a Kona lse a uvw betacam 1400 for the recognition of the other three BNC connectors connect the card where I have a MAC g5 with pci intel FCP as I do if I can help
    Mario Herrera
