Activity › Forums › Avid Media Composer › No sound playback from MC on PC
  • No sound playback from MC on PC
    Posted by Mike Moonch on August 17, 2020 at 3:54 pm
    Hey guys,
    I’m using Avid MC 2020.4 on a PC. I have a black magic 4k intensity card for an external Monitor and a USB-C Scarlett 2i2 device for the audio output. All software that I’m using (ProTools, Premiere, Resolve) are working fine. But Avid doesn’t seem to recognise the Scarlett sound device.
    When I connect some external speaker directly to my external monitor I hear the sound from the Avid. But I only want my picture to go to the monitor and the sound to play through my regular speakers that are connected to the sound device and then to the PC (USB).
    The windows audio is active and not muted for MC.
    When I go to the Audio settings in MC I can’t chose anything but the BMC as audio.
    Any ideas?
    Thanks! Mike
    Glenn Sakatch replied 6 years, 1 month ago 4 Members · 3 Replies
  • Shane Ross
    August 17, 2020 at 5:45 pm
    When you have an IO card installed and used for Avid playout to an external monitor…audio goes to that device. Period. There is no way to send audio out a separate device, or thru the computer. If you have the device active in Avid, audio goes to it. Always.
    Sorry man.
    Shane
    Little Frog Post
  • Pat Horridge
    August 18, 2020 at 6:14 am
    Use an HDMI deembbeder to pull the audio from the hdmi feed and then direct it to your speakers.
    Pat Horridge
    Broadcast & Post Consultant, Trainer, Avid Certified Instructor
    Free online Tutorials at VET digital media academy online http://vimeo.com/channels/752951
    pat@vet.co.uk
  • Glenn Sakatch
    August 21, 2020 at 3:49 pm
    Audio sync can become an issue when you try splitting the audio path from the video path
    Glenn
