Activity Forums Adobe Premiere Pro No sound on export – CS4
  • No sound on export – CS4
    Posted by Nick Convery on May 17, 2012 at 10:34 am
    Hi all,
    I’ve had a scan through the forum and can’t really find a solution to this, I hope you can help!
    I work in a school that uses Prem Pro CS4 across multiple computers. Recently, one particular cluster of computers has stopped exporting audio. The video itself is fine and the audio is present within premiere and on the original clips, it’s only the exported video that is affected.
    I realise that there are loads of variables here, but all I really want to know is if anyone has encountered this before and what caused it in that particular case.
    Opening saved projects on a different computer allows a normal export, so that should eliminate project settings. I’m wondering if this could be sound card or driver related. The problem is persistent across different export formats including h.264, avi and wmv and I’ve tried quite desperate last ditch trials like switching from stereo to mono, using a different bit rate and even just changing the save destination.
    I’ll try to get IT to give me a breakdown of the hardware for this cluster since I can’t access admin tools on my login.
    Cheers
    Nick Convery replied 14 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
