Activity Forums Apple Final Cut Pro Legacy No Sound On Capture
  • No Sound On Capture
    Posted by Shootdc on October 29, 2006 at 7:52 pm
    AJA tech support and I worked hard to diagonse some video capture problems I was experiencing. Final determination – bad card. I have replaced the LHe card in my QuadCore and the video captures fine. The problem is I don’t get incoming audio on the captured material. Audio is definitely coming from the deck – verified by CRT monitor I have for confidence playback. The wiring from the Sony UVW-1800 BetaSp to the AJA breakout cables is exactly the same as it was before replacing the capture card. I have been through Easy Set up a few times and checked my audio ins and outs.
    Any thoughts or suggestions on what else to check?
    Shootdc replied 19 years, 10 months ago 2 Members · 2 Replies
  • Steve Cohen
    October 30, 2006 at 2:21 am
    What version of FCP are you using?
    The reason I ask is that when we upgraded fro 5.1 to 5.1.2 (we have an AJA Io, so it’s a bit different then you’re) I had machine controll, but no audio or video.
    I called AJA and tey had me downgrad the frimware for the IO and that seemed to do the trick.
    Steve Cohen
    Senoir Editor
    O2 Media Inc.
  • Shootdc
    October 30, 2006 at 2:12 pm
    I am running FCP 5.0.4. Thanks for the insight. I’ll call AJA and see what new ideas they have.
