Activity › Forums › DVD Authoring › No Sound in DVD playback – DVD Studio Pro
  • No Sound in DVD playback – DVD Studio Pro
    Posted by Carter Jackson on February 3, 2009 at 5:44 pm
    Hey all.
    So, I can’t believe I’m the only person this has happened to – and I’ve been searching for other similar posts – but it’s either so easy and in front of my face that I can’t see it, or it’s not so common.
    Anyway: I’ve been cutting a reel – less than 2 minutes- compressed it, uploaded it to DVDSP, set the First Play, check it out on Simulator – Everything works.
    Burn the dvd. Successful.
    Playback – No Sound.
    What’s going on? More specifically, what am I doing wrong?
    Now, to give a little more history, I did just delete the preferences, because I was getting the ‘format error’ message. Would that have an effect?
    Any help/suggestions are greatly appreciated!
    Carter
    ps – Oh…and yes, I did check to make sure the sound was on and not muted – on the computer, on the player, everything.
    The confusing thing for me is here that it worked – full video/audio, all synched up – in the DVDSP Simulator before burning…
    Bill Stephan replied 17 years, 7 months ago 3 Members · 2 Replies
  • Michael Sacci
    February 4, 2009 at 2:37 am
    [Carter Jackson] “What’s going on? More specifically, what am I doing wrong?”
    Cannot see what you have done from here. Can you post some specifics. What audio codec are you using?
    Have you tried your disc in more than one player?
  • Bill Stephan
    February 4, 2009 at 6:02 pm
    Did you use MPEG audio? It’s supported on all PAL players, but very few NTSC DVD players can play it. You should be using Dolby Digital .ac3 or AIFF/PCM audio.
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
