Activity Forums VEGAS Pro No Sound from My MPEG2 After Rendering
  • No Sound from My MPEG2 After Rendering
    Posted by Debbie King on May 31, 2014 at 1:57 pm
    Hello Everyone:
    I just completed rendering my film on MGEG2 and downloaded Apple Quicktime for Windows. The movie plays well, but the sound is super low where it is not heard unless I turn the volume to the max. Everything in Sony played well, including the sound. Has this happened to anyone?
    Update. I just read a previous post regarding MPEG no sound. I rendered my film to DVD Architect where the video is rendered with no sound. I also read that audio needs to be rendered so I rendered the audio in Dolby. Now I am not sure how to get the sound with the video. Does anyone know how to do it?
    Many thanks,
    Debbie
    Debbie King replied 12 years, 3 months ago 3 Members · 20 Replies
  • 20 Replies
  • Mike Kujbida
    May 31, 2014 at 4:50 pm
    If you gave both files the same name and rendered them to the same folder, DVD Architect automatically adds the audio file once you load the video file.
  • Debbie King
    May 31, 2014 at 5:06 pm
    Hi Mike:
    Please forgive my naiveté. Do I need a DVD authoring software to load the DVD?
    UPDATE: I found NERO on my computer and attempted to burn my DVD. It turns out that now that I have two separate files, I have exceeded the memory for one disc which holds only 4.3GB. My two files combined hold over 4.8GB. Isn’t there a way that I can render the movie with both audio and video together? I saw in the store where they sell two layer DVD’s. Wouldn’t I need a specific hardware in order to burn double layer DVD’s.
    My thought is many people are rendering separate files and are able to save their film on a DVD. Would you know how all this works?
    Many thanks,
    Debbie
  • Mike Kujbida
    May 31, 2014 at 5:11 pm
    Debbie, by “loading” the DVD, do you mean playing it on your computer?
    If you do, then most of the players (Windows Media Player, VLC, Media Player Classic, etc.) can do that for you.
    If you mean creating the DVD, that’s the job of DVD Architect.
  • Graham Bernard
    June 1, 2014 at 5:26 am
    Sorry to butt in here Mike, i do have to ask Debbie: Debbie what is the PLAY TIME length of your Video?
    Grazie
  • Debbie King
    June 1, 2014 at 8:43 pm
    Hi Grazie:
    1 hour 39 minutes 59 seconds. I was able to access DVD Architect Studio and I have NERO on my computer. Got the movie to play by rendering the audio separately and dropping both files into Architect Studio. I am still confused, however. What I discovered is that my footage is a little more that the average DVD disk memory 4.3GB. I want to either shrink the bitrate or burn it on a dual layer, or would I need an external Dual Layer burner to do this? Can I use NERO exclusively?
    I hear both arguments. Some say I need an external hardware(Staples and Best Buy) and B&H says that I do not. Any clarifications?
    Many thanks,
    Debbie
  • Graham Bernard
    June 1, 2014 at 9:18 pm
    I can easily do a 2 hour DVD on a single platter. You don’t need anything extra.
    Grazie
  • Debbie King
    June 1, 2014 at 9:37 pm
    Hi Grazie:
    My DVD is under 2 hours, but the memory sizes exceeds the average memory the disc allows. I was told that changing the bitrate is an option, but I don’t know how to do that. I was going to get some Dual Layers and create the DvD’s in NERO, if I don’t need an external.
    Many thanks,
    Debbie
  • Graham Bernard
    June 1, 2014 at 9:46 pm
    What Bitrate are you using?
    Grazie
  • Debbie King
    June 1, 2014 at 9:55 pm
    I hope I’m reading it correctly. On my Architect Studio it reads. 6.449 bitrate.
    Many thanks,
    Debbie
  • Graham Bernard
    June 2, 2014 at 6:35 am
    Debbie? Where did you get or have had suggested to you that 6.449 was suitable? That would take your 1hour 40min video into the area of 4.8gb of DVD usage, which WILL put the DVD over its maximum storage abilities. In fact using “Mark’s Bitrate Calculator” I get 4.836gb, which is 104% of that magic 4.7gb limit.
    OK, using the same calculator I’m getting for Video and Audio at a CONSTANT BITRATE(CBR) 5.944. This reflects a usage of the 4.7gb DVD of 4.647gb or 98.87%. So to recap:
    Debbie’s: 6.449(CBR) = 4.836gb
    Graham’s: 5.944(CBR) = 4.647gb
    Your 1hour 40minute project requires a more acute and precise understanding of what can be achieved with a DVD. Once learnt it will hold you in great staid. I truly strongly advise you to download and install Mark’s Bitrate calculator, and take a little time to enter various variables like LENGTH of DVD and your proposed choice of AUDIO quality. This s/w is easy to use and is simple and quick to come to figures that are suitable.
    Whilst here we’ve ONLY spoken of CONSTANT BITRATE (CBR), there is a FURTHER option: VARIABLE BITRATE (VBR). VBR allows the encoder to adjust the bitrate according to the amount of visual “noise” apparent on the Project. Visual noise could be badly captured footage from low light, or of FIREWORKS being let off. Lots of fine, quick movement demands higher rates of encoding to get a better than just “acceptable” quality BUT maintain a roof of that 4.7gb size. Step up VBR, which can take advantage of the ENCODER to do this and will only use HIGHER bitrates when needed. This in turn preserves space on your DVD and allows you to make use of that higher bitrate for better encoding.
    I hope all this helped you? You do NOT need to buy anything extra nor use DUAL layer DVDs. However, I would strongly suggest you use REWRITABLE DVDs while you are testing your numerical experiments – Lol! We’ve all been here before. It took me time to get my head around the the DVD render process/option.
    Cheers
    Grazie
