Activity › Forums › Adobe Encore DVD › no sound
  • no sound
    Posted by Abel Rey on May 24, 2010 at 11:47 pm
    i have 3 sequences in the project that worked fine until now. on one of them the sound disapeared. when i go to premiere everithing is ok there
    Abel Rey replied 16 years, 4 months ago 3 Members · 5 Replies
  • Raja Ashok
    May 25, 2010 at 5:57 am
    Do you have enough hard disk space on your system?. Delete the sequence from Encore and reimport it.
  • Abel Rey
    May 25, 2010 at 6:56 am
    i have enough space on the system and if i try to delete the sequence i got a messege saying : …..cannot be deleted because it is use in the current project. i dont have sound even if i open it from an external backup and it happens only in that specific sequence
  • Paul Benson
    May 26, 2010 at 1:38 am
    I have encountered this, too. Especially if the clip is coming from Premiere. I had to create just an audio WAV file in Premiere and then delete the original audio in Encore and import the WAV file.
    Pauley
  • Raja Ashok
    May 26, 2010 at 2:40 pm
    First, delete the Premiere Sequence from Encore’s timeline then delete it from the project panel.
    You may also want to try this:
    1. Select the Premiere Sequence in Encore
    2. Edit->Edit Original
    (this action launches premiere and open the target project)
    3.In Premiere, playback the sequnece and check the audio, also modify the audio in the sequence and see the changes are reflected in Encore.
  • Abel Rey
    May 26, 2010 at 10:22 pm
    thanks everybody. i dicided not to take chances so i brought the sequence again from premiere and builded it from the bigining
