Activity Forums Blackmagic Design No SDI Output from Multibridge SD
  • No SDI Output from Multibridge SD
    Posted by Thomson Mathew on November 5, 2005 at 11:15 am
    I am using PowerMac G5 2.7 GHz / OS 10.4.2 / FCP 5 / Decklink Driver 5.1.1 /
    Multibridge Driver 1.5.2 these are the configuration.
    The problem is I am not getting the SDI Out from the Multibridge SD BOB, but
    I am getting the SDI In through the Multibridge and Component In/Out and
    also the Composite In/Out. But I am getiing SDI output directly from
    Decklink Plus Card. I am having four similar Multibridge’s and I am facing
    same problem in all the four.
    So, please suggest us where we are missing out at the earliest.
    Sebastine
    Rahul Commerce
    Viveck replied 20 years, 10 months ago 2 Members · 1 Reply
  • Viveck
    November 8, 2005 at 6:24 am
    there is no loop-through out on multibridge
    basically is has two seperate A-D and D-A converters
