Activity Forums DaVinci Resolve No saved projects in autosafe
  • No saved projects in autosafe
    Posted by Ingo Schulten on September 26, 2011 at 8:28 am
    I turned the autosave on in the config page. And every ten minutes the interface is telling me that an autosave is being performed. But in the autosave tap I don’t see any saved projects I could restore. Any ideas why this happens (or better doesn’t happen)?
    Greetings
    Ingo
    Sascha Haber replied 14 years, 12 months ago 4 Members · 11 Replies
  • 11 Replies
  • Sascha Haber
    September 26, 2011 at 1:56 pm
    Refresh button
    A slice of color…
    DaVinci 8.0.1 OSX 10.7
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB eSata 6TB
    GTX 470 / GT 120
    Extreme 3D+ WAVE
    http://www.saschahaber.com
  • Ingo Schulten
    September 26, 2011 at 3:05 pm
    Thanks for the fast reply. Unfortunately it didn’t help. Still no backup available. Any other ideas;-)
    Greetings
    Ingo
  • Marcin Zwolski
    September 26, 2011 at 4:39 pm
    Try setting Automatically save project to backup project.
    See if that helps.
    M
  • Ingo Schulten
    September 26, 2011 at 5:08 pm
    Thanks for the tip. Unfortunately that one didn’t work as well;-(
    Greetings Ingo
  • Jan Martens
    September 27, 2011 at 12:15 am
    I had the same problem. Enabling ‘To backup project’ and pressing ‘Refresh’ (after the first autosave) did work in my case.
  • Ingo Schulten
    September 27, 2011 at 7:45 am
    I will try this and then report;-)
  • Sascha Haber
    September 27, 2011 at 7:53 am
    I guess there are no backups if that setting wasn’t enabled in the first time .
    A slice of color…
    RAID0 8TB eSata 6TB
    GTX 470 / GT 120
    Extreme 3D+ WAVE
  • Ingo Schulten
    September 27, 2011 at 8:19 am
    Hi Sasc,
    what do you mean by not enabled in the first place? I did enable that function, but it simply did not show me any backups. Or do I misunderstand you?
    Greetings
    Ingo
  • Sascha Haber
    September 27, 2011 at 2:48 pm
    The thing is, if you just turned autosave on, it doesnt work.
    It needs to be set to “To backup project” and it has to be saved.
    Then Resolve will first write a full new project and then incremental updates to the database while you are working.
    But is this has not been active prior to work, its probably lost or more precise, never happened.
    A slice of color…
    RAID0 8TB eSata 6TB
    GTX 470 / GT 120
    Extreme 3D+ WAVE
  • Ingo Schulten
    September 28, 2011 at 2:02 pm
    Hi Sascha,
    thanks your way worked. Now I have saved backups. I did not find anything in the manual explaning it the way you did. Did I misread it or is your way based on your own experience?
    Good day
    Ingo
