Activity Forums Apple Final Cut Pro Legacy no reference
  • Posted by Tel Jaba on December 9, 2009 at 11:34 am
    hello guys
    I am trying to print to tape from FCP to Beta SP using the blackmagic card Decklink HD Extreme 3
    I have a ref input option but no output and so I am not able to have a ref to the deck
    what can I do other than renting a black burst generator?
    I am connected component
    Rafael Amador replied 16 years, 9 months ago 4 Members · 3 Replies
  • Jerry Hofmann
    December 9, 2009 at 1:32 pm
    Record it anyway. Then play back. It may well look wrong during record. Mine worked that way without a sync generator anyway. BVW-1800.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Andy Mees
    December 9, 2009 at 2:30 pm
    Tel / Harriet
    If you do have any problem then try using the Deckink’s composite output for sync into the SP deck’s Ref In.
    Best
    Andy
  • Rafael Amador
    December 9, 2009 at 3:17 pm
    An stand alone Betacam recorder doesn’t need any reference when recording Composite or Components.
    Neither you need any ref when you edit Betacam-Betacam.
    The ref-in is only needed in a studio were all the signal from all the devices must be in sync.
    In your setting Video card> Betacam, the Video IN is enough reference. The desk have the pre-roll time to get in sync.
    Different is when you working in digital.
    If it doesn’t works without ref-in, as Jerry points, try the suggestion of Andy. This one should work for sure.
    rafael
    http://www.nagavideo.com
