Activity › Forums › Adobe Premiere Pro › No RealTime export with PPRO and Matrox RT.X2?
  • No RealTime export with PPRO and Matrox RT.X2?
    Posted by Zvi Twersky on August 23, 2007 at 4:31 am
    With Matrox 100 there is an export option for “real-time” export to MPEG2. It works great. With Matrox 2, there is only a Matrox Media Encoder (similar to the Adobe one) and when I choose to export to MPEG2, it jitters during export and it freezes in the middle of the export and I have to restart PPRO. (Every time it will freeze on a different spot).
    Where is the RealTime export in PPRO with Matrox 2?
    Zvi Twersky replied 19 years, 1 month ago 2 Members · 2 Replies
  • Eric Jurgenson
    August 23, 2007 at 1:31 pm
    The RTX2 actually exports considerably faster than real time for standard def, depending on the power of your CPU. On my single Core2 Quad workstation, I get about 4x real time. As to why it is stopping in the middle, I don’t know. You could try importing your project into a non-Matrox project, and render from there to see if the problem is with the RTX2 or something else. The RTX2 export seems about 30-40% faster than the non-RTX2 export on my system.
    What are your system specs?
  • Zvi Twersky
    August 23, 2007 at 5:01 pm
    The computer has 2 CPU’s each 3.4 I think and 2GB of RAM. I will try to import it to a regular DV project like you said. Good idea.
