Activity Forums AJA Video Systems no real time output from Kona 2 in DVC Pro 720p50
  • no real time output from Kona 2 in DVC Pro 720p50
    Posted by Itamar Kool on June 26, 2007 at 9:32 am
    I imported files from my firestore, shot with a Panasonic HVX 200 in 720p25. When I play it out in FCP 5.1.4, I get the picture only on my SD video monitor when I stop. Not while playing. I want to see the movements on my video monitor becaus of the progressive mode
    Kool En De Anderen
    dual 1.8 gig G5/Mac OS 10.4.8/Kona 2/Hugh 800 G diskarray, fibrechannel/FCP 5.1.2/AE 7 Pro
    http://www.koolendeanderen.nl
    Michael Tauber replied 19 years, 2 months ago 5 Members · 8 Replies
  • 8 Replies
  • Walter Biscardi
    June 26, 2007 at 11:23 am
    What Easy Setup are you using? I believe you need to manually create this setup using the 720p/60 Setup as your guide.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Itamar Kool
    June 26, 2007 at 11:45 am
    Walter, thanks for the fast response. I tried several set ups, with different video playback modes in FCP. My Kona control panel has the buffer set to 720p50 and my current play back mode in FCP is AJA Kona 720p60. Already tried 720p50DVCPro HD and 720p25DVC 8bits Varicam and many others….
    Kool En De Anderen
  • Itamar Kool
    Kool En De Anderen
  • Gary Adcock
    June 26, 2007 at 1:17 pm
    [Itamar Kool] “My Kona control panel has the buffer set to 720p50 and my current play back mode in FCP is AJA Kona 720p60”
    your video out needs to be 720p50 for 25p workflows
    did you try the Kona PAL 8bit to DVCPro50 easy set up- ti works for me.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • Itamar Kool
    June 26, 2007 at 6:31 pm
    I just tried. Didn’t work here. But I heard that this problem has been solved in FCS 2 which is in my new Intel Mac that I am going to use this week… So I hope that alle will be good soon…..
    Kool En De Anderen
  • Nathan Thompson
    June 26, 2007 at 8:53 pm
    Hi.
    Did you make sure your playback settings were set to “all frames”?
    Nate
  • Itamar Kool
    June 27, 2007 at 9:16 am
    Yes, I did. Just installed my new 8 core which has FCS 2 installed and now my video monitor does play real time. Must be something thay fixed with FCP 6 or AJA. Thanks for the responses
    Kool En De Anderen
  • Michael Tauber
    July 5, 2007 at 1:05 pm
    “AJA Kona 720p25 8 Bit DVCProHD (1280 x 720)” is the correct setting in FCP 5.1.x
    In FCP 6 you can use the normal 720p50 output option.
