Activity Forums Adobe Premiere Pro no prores output ??
  • no prores output ??
    Posted by Anhtu Vu on November 5, 2012 at 4:32 pm
    Anyone knows if by installing FCPX, Prores will be available to other apps, like Premiere and AE CS6 ?? This was the case with the fcp7.
    I just install FCPX and i still can’t output to prores in Premiere or AE. Thx
    Tom Daigon replied 13 years, 10 months ago 7 Members · 13 Replies
  • 13 Replies
  • Joseph W. bourke
    November 5, 2012 at 4:49 pm
    Apple kept Prores under very tight control, only allowing its format to be output by a handful of manufacturers hardware. As a result of this, you’ll only find the capability to read Prores formats in AE and PPro, but not to output them. If you do a search on Prores in these forums, you’ll find a list of the hardware which does output to Prores.
    And that said, if you don’t mind going under the hood a bit, you can get Prores output from FFMPEG:
    https://ffmpeg.org/
    It just takes a bit of work, and I haven’t tried it, but I’m sure there’s someone in this forum who has.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Alex Udell
    November 5, 2012 at 4:50 pm
    not sure about AE….
    for PPro…you might need to jump into AME and set it up there first….
    then it should be available in PPRo…
    Alex
  • Tim Kolb
    November 5, 2012 at 8:42 pm
    Is ProRes not available in the export settings under “QuickTime”? You may have to access the codec from the video tab in the exporter panel, but AFAIK, installing FCPX, or even Motion should put the ProRes encoder on a Mac.
    It is limited to read only on Windows.
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Anhtu Vu
    November 5, 2012 at 10:38 pm
    Well, i just installed FCPX and there’s is no Prores export in PP and AE.
  • Tim Kolb
    November 5, 2012 at 10:54 pm
    How do you know this? Can you walk us through the steps you’re taking?
    Have you found all he rest of the QuickTime codecs?
    TimK,
    Kolb Productions,
  • Walter Soyka
    November 6, 2012 at 1:36 am
    FCPX is built on the AV Foundation framework, not QuickTime. The FCPX installer does not include the QuickTime versions of the ProRes codecs.
    To use ProRes in Ae/Pr/AME/etc., download the QuickTime codecs here:
    https://support.apple.com/kb/DL1396
    Walter Soyka
  • Anhtu Vu
    November 6, 2012 at 1:57 am
    ah…where have you been Walter 🙂 thanks for the info
  • Walter Soyka
    November 6, 2012 at 2:06 am
    [Anhtu Vu] “ah…where have you been Walter 🙂 thanks for the info”
    Just giving it a dramatic pause 🙂
    Happy to help.
    Walter Soyka
  • Tim Kolb
    November 6, 2012 at 3:35 pm
    Good info Walter…does Motion install the legacy codec?
    This sheltering of ProRes by Apple is getting even more frustrating than it has been in the past.
    TimK,
    Kolb Productions,
  • Anhtu Vu
    November 7, 2012 at 11:10 pm
    Motion will install the Prores codec and it will be available to other QT apps.
