Activity Forums Apple Final Cut Pro Legacy No progress bar when rendering.
  • No progress bar when rendering.
    Posted by Jorge on July 4, 2005 at 6:38 am
    When I render I don’t see the usual progress bar that indicates the percentage that has been rendered, instead I get the same window that says “writting video” but with the spinning candy cane instead of the progress bar and percent, really annoying. I’m trying to avoid trashing prefs mainly because everything else is working fine and all the favorites but in case I have no other option would it be ok to replace those prefs with the prefs from another system I have with the same exact configuration?
    Thanks in advance for any help.
    Jorge replied 21 years, 2 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    July 4, 2005 at 1:51 pm
    Just drag your favorites to a project file, save it to add them back and trash the prefs…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Jorge
    July 4, 2005 at 6:02 pm
    Thank you Jerry.
