Activity › Forums › VEGAS Pro › No preview on Canopus ADVC 100 in Vegas 6?
  • No preview on Canopus ADVC 100 in Vegas 6?
    Posted by Barend Jasper on December 3, 2005 at 10:59 am
    Ladies, gentlemen,
    I just discovered previewing on a Canopus ADVC 100 no longer works in vegas Video 6. It works fine in Vegas 5, but for some reason Vegas 6(c) refuses it. Any idea what’s happeining here?
    My apologies if this has been discussed here already.
    Barend Jasper
    Rob Mack replied 20 years, 10 months ago 7 Members · 7 Replies
  • 7 Replies
  • Gary Kleiner
    December 3, 2005 at 3:07 pm
    Sometimes, if you have mutiple instances of Vegas and/or capture open, the external preview is not released when you switch between them. If you have a Vegas 5 project open too, close that and see if yur Vegas 6 project starts previewing.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Jeremy Rochefort
    December 3, 2005 at 4:40 pm
    Also be sure that the ADVC is set to digital and not analogue
    Cheers
    Jeremy
    MJ Productions
    MJ Productions
  • Harold Brown
    December 3, 2005 at 5:15 pm
    I have the Canopus ADVC 100 and it always works the first time but if I exit Vegas Capture and then later open it back up again without exiting Vegas6 first it will have problems. Closing out of everything and opening it back up usually works. I don’t recall having this problem in Vegas5.
    Harold
  • Barend Jasper
    December 3, 2005 at 8:43 pm
    Thanks everyone for your help.
    I haven’t found the answer yet though.
    We’ve got Vegas 6c running on 2 PC’s, and both PC’s have exactly the same problem: the image doesn’t appear on the TV’s connected to the 2 Canopus AD/VC100’s.
    -The switch is set to digital input
    -We don’t have Vegas 5 and 6 running simultaneously
    In both cases Vegas 5 work fine, but not with Vegas 6.
    In both cases they recognise the connected device…
    Aaargh. Sometimes one misses analogue video (although only for 2 seconds).
    Barend
  • Mike Kujbida
    December 4, 2005 at 4:48 am
    I’m sure you’ve checked but, because Vegas 6 has more preview options than V5, confirm that yours is set to the correct one.
  • Stephen Mann
    December 5, 2005 at 3:04 am
    My experience was exactly the opposite. My Canopus ADVC100 was unreliable in V5, and it works perfectly in V6.
  • Rob Mack
    December 5, 2005 at 6:16 am
    Mine has worked fine in 4, 5, and 6. No troubles aside from a few puffs of smoke.
    Rob Mack
