Activity › Forums › VEGAS Pro › No Plug-ins will work!
  • No Plug-ins will work!
    Posted by Matthew Shabs on July 14, 2010 at 2:01 am
    Hello,
    I am using Sony Vegas Pro 9.0 (64-bit) on Windows 7 Ultimate, and I am trying to use the ‘Pitch Shift’ plug-in
    I select my Audio layer, press the ‘Track FX’ button and try to add in the ‘Pitch Shift’
    However, for that, and ALL other Plug-ins, I get an error saying the following:
    “The Plug-in could not be run. One or more components required to run this plug-in may be missing.
    If a hardware key (dongle) is required to operate this plug-in, ensure that it is properly installed.
    The COM object failed to initialize.”
    When I click the ‘Details’ button the text says:
    “The Plug-in ‘Pitch Shift’ failed to load. Please make sure the plug-in is properly installed.”
    Matthew Shabs replied 16 years, 2 months ago 3 Members · 6 Replies
  • Douglas Spotted eagle
    July 14, 2010 at 6:59 am
    Some plugs don’t work in 64bit. Try the 32bit version. Open the file in Forge and save a copy of the audio.
    You know you can pitch shift in Vegas without a plugin, right?
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Matthew Shabs
    July 14, 2010 at 12:07 pm
    Really? How do I pitch shift without using the Plug-in?
  • John Rofrano
    July 14, 2010 at 11:17 pm
    “=” key to shift up and and “-” key to shift down. Hold the Shift key to pitch shift octaves.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Matthew Shabs
    July 15, 2010 at 9:43 pm
    I selected the clip and pressed the ‘-‘ key and nothing. I tried the ‘=’ key and same thing, I also tried holding Shift for both of them and the audio remained the same for the clips.
  • John Rofrano
    July 16, 2010 at 2:17 am
    Did you specifically select the audio clip and not the video clip? You must have the audio clip (and audio track) highlighted for this to work.
    ~jr
  • Matthew Shabs
    July 16, 2010 at 12:55 pm
    Yaa, I have just the audio clip and not the video. I also tried adding a new audio track so that only the clip I want to alter pitch has it’s on track and it still won’t work
