Activity Forums Apple Final Cut Pro No playback on two audio channels imported as ‘four mono’
  • No playback on two audio channels imported as ‘four mono’
    Posted by Jesse Freeston on June 5, 2017 at 10:09 pm
    FCPX imports audio as ‘Four Mono’ with audio from the lapel and boom mics on channels 1 and 2 respectively. Channels 3 and 4 are empty. The waveforms show and the meters go up and down, but there is no playback. (see screengrab)
    If I switch to ‘Two Stereo’ in the Inspector I can hear the playback, but I lose the ability to adjust the levels of the two mics individually.
    Any ideas?
    I am editing on OS X Sierra and FCPX 10.3.1.
    Shot with Sony PXW-X70.
    Jesse Freeston
    Documentary Filmmaker/Editor/Shooter
    Jeff Markgraf replied 9 years, 3 months ago 3 Members · 3 Replies
  • Duncan Craig
    June 6, 2017 at 9:08 am
    Edit the multicam clip into a timeline and it will playback the audio.
    I’m having the same problem here.
    It’s happening since I update to the recent version, I expect it’s a ‘feature’ of the new Roles related stuff, but it’s a real PITA.
    FS100, EX1, GoPro, 2x Hacks, FCPX etc
  • Jesse Freeston
    June 20, 2017 at 9:01 pm
    Hey Duncan!
    That’s what I’ve been doing too, a bit of a PITA as you say. Have you found a solution in the last couple weeks?
    Jesse Freeston
  • Jeff Markgraf
    June 21, 2017 at 12:06 am
    Duncan & Jesse –
    See the reply to Ben above (or below) this thread and try the MIDI configuration fix. Hope it helps.
