Activity › Forums › Boris FX Particle Illusion › No PAL DV AVI output
  • No PAL DV AVI output
    Posted by Dean Murray on April 4, 2008 at 5:39 pm
    Hi there,
    I’ve just recently purchased the great Particle Illusion 3 and have found a problem with exporting as PAL DV.
    The stage is set as 720 x 576 and I change the DV codec output settings to PAL DV, but the resulting AVI files are always 720 x 480.
    Is the a known issue? and are there any workarounds except the exporting as uncompressed or PNG sequences etc.?
    Thanks in advance,
    Dean
    Michael Callaghan replied 17 years, 10 months ago 3 Members · 6 Replies
  • Alan Lorence
    April 4, 2008 at 8:54 pm
    It’s the codec that’s setting it to that size — is there a setting in the codec (use the “configure” button in the codec chooser dialog) that controls that?
    If you can let me know where I can get that codec I can take a look, because other people are having this happen too.
    Alan.
    http://www.wondertouch.com
  • Dean Murray
    April 7, 2008 at 10:02 am
    Hi Alan,
    I’d already found the PAL setting in the CODEC when I posted, unfortunately it was nothing as simple as that!
    I had assumed that this CODEC came with Particle Illusion as I don’t recall having the option from other applications before, but checking on another PC that doesn’t have PI3 installed I still get the DV Video output option from other programs, which incidentally doesn’t even output due to a different error!
    It’s not easy to see which DV CODEC is being used, as the About option does not display any information, but I suspect this may be the Windows Default DV CODEC (QDV.dll) and this is kind of also confirmed by GSpot.
    Dean
  • Alan Lorence
    April 7, 2008 at 12:51 pm
    particleIllusion doesn’t install any codecs.
    [Dean Murray] “It’s not easy to see which DV CODEC is being used”
    If you have more than one DV codec, they should all show up in the codec list in particleIllusion — I’m not sure what you mean.
    Alan.
  • Dean Murray
    April 8, 2008 at 8:33 am
    Hi Alan,
    I’m using Particle Illusion on Windows XP Pro and the CODEC I’m trying to export PAL DV from is called “DV Video Encoder”.
    Dean
  • Michael Callaghan
    November 28, 2008 at 7:37 pm
    Hi Dean, did you ever find a workaround for this problem as i have encountered exactly the same issue using Particle Illusion SE free trial. Each time i output to pal using DV Video Encoder and import into Adobe Prem Pro the image is 720/480. I am impressed with the effects etc but would need to resolve this issue before purchasing.
    Any help would be appreciated
    Thanks, Michael
  • Michael Callaghan
    November 28, 2008 at 7:39 pm
    Thanks, Michael
