Activity Forums Blackmagic Design no output on decklink SP
  • no output on decklink SP
    Posted by Mark Bowes on May 19, 2005 at 2:50 pm
    Hi I have just installed a decklink SP card on to my XP machine ( has a geforce 5500 graphics card that i use to run 2 21″ displays) running Premiere Pro.
    i can capture OK but have no output YUV to my Beta sp deck or monitormonitor i have tried all combinations but i can not gett any output from the card
    please in need of serious help have client brathing down my neck
    kind regards
    mark
    Mark Bowes replied 21 years, 3 months ago 2 Members · 2 Replies
  • Jeff Brown
    May 20, 2005 at 2:15 pm
    Have you checked in DL Hardware control that you are using YUV output and not Y output (composite) ? Do you have any output at all? BW/switched color channels, noise, anything?
    -jeff
  • Mark Bowes
    May 20, 2005 at 2:32 pm
    checked in DL Hardware control set for YUV, output is black, on sdi all i have is Snow but the sound is ok both on analog and didital outputs i have also tried the composite out
    do you know if the decklink sp works with premiere pro 1 ( i do not have version 1.5)
    i have installed al the lates drivers frlom the decklink site also runining windows Xp profesional service pack 2
