Activity Forums Blackmagic Design No output from Decklink when digitizing
  • No output from Decklink when digitizing
    Posted by Juliett on February 8, 2006 at 6:16 pm
    Hi Everyone!
    I have 4 edit suites running on FCP v 5.0.2 running on Mac OS X v10.4.2. (Declink hd Pro dual link 5.1.1)
    In 2 of the edit suites; when digitizing the image does not output to the Apple Cinema Display. (Must note that the image comes through the Log and Capture tool, but not on the Cinema Display)
    The deck I used for digitizing was Sony J3 digi beta deck.
    When I connect the SDI out of the deck directly into the HD Link, I manage to get picture so I guess this eliminates a possibility of a fault with either the display or the hd link.
    Why the picture is not output to the cinema display when I digitize, is it a problem with the decklink card.
    PS: I am confident that my Audio Video Settings are correct as I do get a picture coming through the fcp in the capture tool.
    Regards
    Zee.
    Kristian Lam replied 20 years, 6 months ago 3 Members · 3 Replies
  • Nico Sandhof
    February 8, 2006 at 6:29 pm
    preference settings for your decklink hd: “black video output to deck in capture” -> disabled
  • Juliett
    February 9, 2006 at 12:18 pm
    Hi Nico
    Thank you very much for your advice about the decklink settings, it just solved my problem. 🙂
    I have other problems with my other suites which I will post now.
    Thank You
    Zee.
  • Kristian Lam
    February 16, 2006 at 5:33 am
    Hi Zee,
    Have you tried contacting us via the support webform? I’m asking this because the past emails I had responded to bounced back and there was no way I could reach you.
    regards
    Kristian
    Blackmagic Design
