Activity › Forums › Adobe Premiere Pro › NO MXF export
  • NO MXF export
    Posted by Goutom Ain on February 1, 2014 at 1:14 pm
    I am using AP cs6 but while exporting a video i am getting p2 movie and not mxf 0p1a export preset. Is there any thing i am missing. Adobe media encoder has the same preset but not in AP. Please help me as i need to export video in single mxf file.
    AP version: cs 6.0.0
    AME version: cs 6.0.3.1
    Imad Abusumayah replied 11 years, 9 months ago 6 Members · 6 Replies
  • Jeff Pulera
    February 1, 2014 at 3:07 pm
    Have you tried “P2 Movie” export format?
    Jeff Pulera
    Safe Harbor Computers
  • Goutom Ain
    February 1, 2014 at 3:38 pm
    Hi, thnx fr ur quick reply. i tried p2 movie but tht export mxf audio and video file seperated witj panasonic p2 folder structure. i want single mxf file directly from ap which is possible with mxf encoder.
  • Chris Tompkins
    February 1, 2014 at 4:58 pm
    Exporting P2 does not make separate files.
    Try it. Export a sequence to P2.
    Then open media browser and bring in the P2 clip. The audio and video will be linked.
    Chris
  • Thomas Nord
    February 4, 2014 at 3:13 am
    Exporting to P2 will give you separate audio and video files on the hard drive which is what the OP was referring to.
    Goutom, do you have the MXF OP1a option in Premiere Pro if you choose File > Export? I’m curious if this is just limited to AME or is also affecting your Premiere Pro installation. If it is in both, you should try logging out and back in of your Creative Cloud account as it is most likely an issue with the licensing for that codec not being properly detected.
  • Tim Kolb
    February 4, 2014 at 9:00 pm
    Have you checked on software updates?
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Imad Abusumayah
    December 22, 2014 at 11:00 am
    hi how are u did u fix the MXF problem in exporting files i have the same problem i downloaded all the codecs to my PC please help me
