Activity Forums Adobe Premiere Pro NO MPEG 2-DVD option in Cs6 PP
  • Bec Mills
    January 15, 2013 at 11:13 pm
    Hi Kevin,
    Thanks for the tip- I wasn’t able to select the deactivate as it was in grey. I uninstalled, then re-installed and this did the trick.
    I now have the mpeg 2 option and have run all relevant upgrades..seems to be working fine. I have posted in the APP forum with regards to where Im at with needing a few pointers for exporting to dvd..i don’t want to double post which i have before)-
  • Pedro Romero
    January 1, 2016 at 8:41 pm
    1 – Reinstall Premiére.
    2 – Open the Premiere in test mode (trial)
    3 – Create a project and export (the option MPEG2 and MPEG2 DVD will appear)
    4 – Export the movie and close Premiére.
    5 – You can now use the crack to release the program.
    6 – Open the Premiere released and all functions.
  • Tim Kolb
    January 1, 2016 at 10:53 pm
    Keep in mind that MPEG2-DVD are standard definition (NTSC or PAL) for red laser DVDs.
    1440×1080 is high definition, 1.33 PAR, which would be found under MPEG2-Blu Ray, and only possible to burn onto a Blu Ray disc.
    TimK,
    Director, Consultant
    Video Producer at I-CAR
Page 2 of 2
