Activity › Forums › Compression Techniques › No MP3 option in Squeeze 4.1 Compression Suite
  • No MP3 option in Squeeze 4.1 Compression Suite
    Posted by John Mark seck on August 30, 2005 at 3:24 pm
    Hi All,
    Using Squeeze 4.1 to compress to FLV but I get no options for audio codec. Ideally I’d like to compress to MP3 but I don’t see the codec…actually I see no codecs in the pulldown menu.
    Any ideas…?
    John
    Charles Simonson replied 21 years, 1 month ago 2 Members · 1 Reply
  • Charles Simonson
    August 31, 2005 at 1:54 am
    Sounds like Squeeze doesn’t recognize your audio file. Is the lack of audio encoding options the same for all encoders in Squeeze? Are you using one of the FLV presets? You can also select alternate audio sources (like a second audio file) in Squeeze if need be.
