Activity Forums Apple Final Cut Pro Legacy “No movie in file” in FCP 5?
  • “No movie in file” in FCP 5?
    Posted by Ben Hume-paton on October 9, 2005 at 11:31 am
    Dear Creative Cow
    I have been using the latest FCP 5 on the latest G5 with the latest OS X, I had a bit of a melt down with my HUGE raid drive and had to re-import some footage. Complete disaster, wasted two days but now semi back to normal except I am now plagued by gremlins, most of which I can sort out but the big one is:
    when I play some sequences it stops at a certain point and says “No movie in file”, I play the sequence again and it stops at the same point and says “General Error” then quits out of FCP 5. I have reimported the clip, redigitized the clip, done the disk utility thing, but what ever I do it still has the same problem in the sequence timeline. I have copied the sequence to the a new sequence and the same problem occurs. I can’t render past this point either. Any suggestions ? I only have 8 programmes to cut some of which are airing at the end of the month so no panic?
    Kind regards
    Ben
    David Bogie replied 20 years, 11 months ago 2 Members · 1 Reply
  • David Bogie
    October 10, 2005 at 3:42 pm
    Binary test. Try copying the media file to a another drive and reconnect to it. If it still hangs in the same place, your media file is bad. Is it a bad capture, a bad FW cable, a bad tape, or a bad drive? More binary tests.
    bogiesan
