Activity › Forums › Adobe Premiere Pro › No more Tiff-Sequence in PremPro 2 ?
Posted by __peter__ on September 28, 2006 at 10:31 amHello 🙂
I have to import footage as a Tiff-Sequence and a JPG-Sequence. But all I get is a single image. No Sequence. In PremPro1.5 there was a option if one would like to import the sequence or the single picture. But it’s gone. So how is that working in the new version ?
Peter
__peter__ replied 20 years ago 4 Members · 6 Replies -
Lex Park
September 28, 2006 at 3:43 pmTo import numbered still-image files as one clip:
Make sure that each still-image file name contains an equal number of digits at the end and has the correct file extension
__peter__
September 29, 2006 at 8:00 amThanks for Your reply, but …
that checkbox for numbered stills is simply nomore there in PremierePro 2.0
It was there all the years in PremPro 1 and 1.5 but no more.Or has it changed it’s position in Layout ? I cannot see it …
Any more ideas ?
Peter
Blast1
September 29, 2006 at 11:14 amThe Numbered Sequence check box is still in the Import Window on ver 2 right under the File Type drop down menu, same as ver 1/1.5, You aren’t by any chance using a trial tryout version?
__peter__
September 29, 2006 at 12:00 pmThe only thing I can imagine is, that I am running a German Windows-System and the English Premiere Pro (for some reasons about the editing card).
That means that most of the Standard Import Dialog-Box is German. Maybe thats why the additional checkbox isn’t there.
So still no solution for importing Sequences …
Any ideas anyone ?
Peter
Uwe Lansing
September 29, 2006 at 1:10 pmPeter, check out this thread:
https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=3&postid=863380Maybe it
__peter__
September 29, 2006 at 4:36 pmThanks Uwe,
thats the solution. Strange enough, but I am glad it works now.
Thank You all again!
Peter
