Activity Forums Adobe After Effects no more scan lines?
  • no more scan lines?
    Posted by Charles Ferran on February 17, 2009 at 4:02 pm
    I’ve been using After Effects for awhile now but I’ve had this itching question and just can’t take it anymore!!! why, nine times out of ten, if I bring video into After Effects that has scan lines, can I just export it and have the lines disappear, I always just accepted it as the magic of AE but I really think I should know, understanding this will probably make me a much better editor! thanks!
    P.S. graduated college literally a year ago this week and three months into my first editing job, so I’m trying to learn all I can!
    Charles Ferran replied 17 years, 7 months ago 3 Members · 3 Replies
  • Todd Kopriva
    February 17, 2009 at 4:37 pm
    After Effects automatically separates fields for D1 and DV video footage items. (You can manually separate fields for all other types of video footage in the Interpret Footage dialog box.)
    For more information, see the “Separate video fields” and “Interlaced video, noninterlaced video, and progressive scanning” sections of After Effects Help.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Kevin Camp
    February 17, 2009 at 4:48 pm
    if you bring in a footage type that ae thinks is commonly interlaced (like dv), then it interpret it as interlaced and try to separate the fields. then by default, ae renders progressive, so it will often de-interlace your video. if you don’t want this to happen, there are ways to handle this…
    if you select the footage in the project window, at the top of the project window you’ll see the thumbnail and some info on the footage. one bit of info is often the field interpretation (like, separating (even)). this means that ae is separating the fields, even lines first. if you don’t want that (or maybe ae is wrong), select the footage and choose file>interpret footage>main. here you can define how you want the footage to be interpreted.
    most of the time you will want ae to separate fields if the footage is interlaced, however, you may want to put the fields back when you render.
    if you want a field render, when you add the comp to the render queue, click the render settings and set field render to the correct dominance. now when you render the comp, it will interlace the render (both for the footage and any motion graphics/effects you’ve added). note that the render will usually take twice as long as ae is rendering and doing calculations at 60 fields per second vs. 30 frames per second.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Charles Ferran
    February 17, 2009 at 5:04 pm
    I learned something! thanks guys!
