Activity › Forums › Apple Final Cut Pro Legacy › No more RT viewing…. ARGH!
  • No more RT viewing…. ARGH!
    Posted by Seth Hancock on June 22, 2006 at 2:14 pm
    I have been using FCP for some time now and have never had a problem with RT viewing on my external monitors. However, recently I just get still images on my Sony and JVC broadcast monitors when I playback. I can see everything in RT in the viewer but just frames on the monitors. I have gone over the settings many, many, many times and yet nothing has changed. Am I missing something? Here are my current settings…
    Viewing ALL FRAMES
    Playback Setting – Blackmagic Decklink SP 8 bit, RT – Safe, Video Quality – Dynamic, Frame Rate – Dynamic.
    All of my video output settings are set this way. This is the case regardless of using the Decklink card or firewire. Any thoughts?
    Seth
    OSX -10.4.6
    FCP – 5.0.4
    Opportunity is missed by most people because it is dressed in overalls and looks like work.
    Thomas A. Edison
    Peter Mcauley replied 20 years, 3 months ago 4 Members · 8 Replies
  • 8 Replies
  • Bret Williams
    June 22, 2006 at 2:33 pm
    Is part of your canvas widow obscured in any way? For example are you slighly zoomed in where just even a pixel of the image isn’t visible?
  • Seth Hancock
    June 22, 2006 at 3:32 pm
    Thanks for the reply. But there is nothing overlapping or obscuring the viewer or canvas. I have the image size set to 100% and “Sync Off” is selected. That’s why this is so frustrating to me since nothing has changed in my external configurations recently.
    Seth
    Thomas A. Edison
  • Debe
    June 22, 2006 at 3:38 pm
    Instead of having the Canvas set to 100%, try “Fit to Window”.
    debe
  • Seth Hancock
    June 22, 2006 at 3:43 pm
    Thanks for the reply debe. I tried your suggestion and nothing changed. Everything plays fine on my canvas and cinema display but still just appears as frames in the external monitors either firewire or decklink.
    Seth
    Thomas A. Edison
  • Debe
    June 22, 2006 at 4:03 pm
    How about just a good ol’ fashioned restart?
    debe
  • Seth Hancock
    June 22, 2006 at 4:05 pm
    Yeah, I did that this morning with the exact same result. That’s more reason why I am frustrated.
    Seth
    Thomas A. Edison
  • Debe
    June 22, 2006 at 4:08 pm
    Dangit! Sorry adguy! I was hoping for the easy answer for you!
    Other than a total shutdown and power off, wait at least 3 minutes and power back up, I’m outta ideas.
    And something tells me you may have already gone down that road…
    debe
  • Peter Mcauley
    June 22, 2006 at 7:57 pm
    Is your timeline set to 29.97 or does the Blackmagic card have the ability to add pull downs if your at 23.98
    Peter McAuley
    Axyz Edit
    Toronto
    G5 dual 2.0
    4 gigs ram
    10.4.3
    FCP 5.04
    QT 7.03
    Kona 2 v1.1.4 with K Box
    4 X 250 gig external F800 Lacie firewire drive
    2 X 23″ Apple cinema display
