Activity › Forums › Adobe Premiere Pro › no more audio in premiere with new USB headset
  • no more audio in premiere with new USB headset
    Posted by Release2 on February 4, 2007 at 9:01 am
    recently got a new Logitech 350 USB headset, but it’s caused the sound to stop working in all my existing premiere files (and new ones). the waveforms are still there, and if i bring up the audio mixer, i see the waveforms moving, but i hear nothing. otherwise, sound works normally on my pc, through the new headphones. except… in a music tracking program that i use, the audio also stopped working when i plugged in the new headset, and i had to go into the settings and tell the program to send the sound to my new headset instead of what it was set to before. but in premiere, i can’t find any setting like that to fix the problem.
    also, i’m not sure if this might be related. i noticed that when i recorded something in Fraps with the new headset — instead of recording the audio from the program i was in as it is supposed to, it recorded my mic, and you could hear me typing and whatnot.. instead of hearing the sounds of the program i was in.
    Release2 replied 19 years, 8 months ago 2 Members · 2 Replies
  • Blast1
    February 5, 2007 at 4:22 am
    Check the settings under Preferences, and check to see if you sound card has a output to your headset.
  • Release2
    February 7, 2007 at 3:49 am
    thanks a lot 🙂
