Activity Forums VEGAS Pro No longer seeing default transitions
  • No longer seeing default transitions
    Posted by John Lee on December 10, 2013 at 9:57 pm
    Hello,
    I make sports highlights and have always used the standard fade transition between clips. I’ve also, in the past, added multiple clips and SV puts in the transitions automatically.
    Something must have happened because now if I push two clips already on the track together, there is ZERO transition. If I add in multiple clips simultaneously, there placed adjacent to one another, but there is no transition, either.
    Not sure what happened, but how to I fix this? I assume there must be a setting that enables automatic transitions. If I try to slide two clips together, I don’t see the usual “sine wave” that shows the clips fading into one another.
    Some help would really be appreciated. Thanks.
    Steve Rhoden replied 12 years, 9 months ago 2 Members · 3 Replies
