Activity › Forums › Adobe Premiere Pro › No longer able to open .vob files in Adobe Premiere Pro CS5
  • No longer able to open .vob files in Adobe Premiere Pro CS5
    Posted by David Esteban on March 27, 2011 at 2:04 am
    Hi everybody. Here is the thing. A few month ago i started a project in Adobe premiere to edit a some family videos. I edited a few hours an then i left the project along with the dvd files saved in my hard drive. I wasn’t able to finish my editing back then, so now that i have more time I decide to continue where i left.
    However when i open the project this time, i found that all the clips are offline. Ok, no big deal, maybe i moved them, let’s replace the clip. Not working. I don’t know what happened in this few month but the i’m not longer able to open the same clips. The message i get is: “The file has an unsupported compression type”. I tried renaming the files to .mpg, and i get the same message.
    Any help would be appreciated.
    Greg Brush replied 14 years, 11 months ago 3 Members · 4 Replies
  • Tim Kolb
    March 28, 2011 at 4:55 pm
    You aren’t running the trial version for some reason?
    TimK,
    Director, Consultant
    Kolb Productions,
  • David Esteban
    March 28, 2011 at 10:33 pm
    No, i just checked it (Help>about) and it seems to be the full version, i don’t see anything that refer to a trial version. Although i remember unistalling and installing the software a few months ago, maybe i did something wrong when i was re-installing it…. i will try to re-install once again, and see what happen. Thanks for your reply.
  • Tim Kolb
    March 28, 2011 at 10:53 pm
    After install and successful activation, there are additional codecs that need to be installed, the MPEG codecs are part of that.
    Did you de-activate the software before you uninstalled it? There are a finite number of activations available for each license…
    TimK,
    Kolb Productions,
  • Greg Brush
    October 16, 2011 at 2:59 pm
    new to CS5 and Premiere… where/when do you load the additional MPEG codecs. everything thing seems to be working other than bring in mpg files to edit.
