Activity › Forums › Apple Final Cut Pro Legacy › no kona LH preset for 720p 29.97?
  • no kona LH preset for 720p 29.97?
    Posted by Bob Flood on May 5, 2009 at 1:46 pm
    Hello and happy 5 may!
    I have a bunch of footage, 720P @ 29.97, shot on P2, and when i bring it into FCP 5.1.4 i have to reset my sequence time to 29.97 to get real time playback.
    the easy setup defaults to 59.94 which does not let my footage play in reatime.
    I have created a preset where sequence settings are 29.97, but is this right? is this cuz i am still using 5? should there not be a kona lh easy setup for 720p 29.97? and can i really save money on my car insurance by switching to geico?
    thanx in advance!
    “I like video because its so fast!”
    Bob Flood
    Greer & Associates, Inc.
    Bob Flood replied 17 years, 4 months ago 3 Members · 3 Replies
  • Rafael Amador
    May 5, 2009 at 3:12 pm
    Hi Bob,
    I think there is no 720p30 tape-based system, so no much need to make a capture preset for an inexistent format (?).
    If your footage is p29,97 your sequence must be the same.
    In FC6 there is a Sequence Preset for Proress 720p30 (29’97).
    rafael
    PS: Hope this is not poisoned information from PAL-land:-)
    http://www.nagavideo.com
  • Shane Ross
    May 5, 2009 at 3:27 pm
    This is not poisoned information. 720p is a 60 frame format. 1080i is a 30 frame format. If you want to work with 720p in a 30 frame format, you need to make a custom preset.
    Shane
  • Bob Flood
    May 5, 2009 at 4:01 pm
    Shane and Rafael
    Thanx for the response!
    i will be saying the big DUH now!
    Bob Flood
