Activity › Forums › Adobe Premiere Pro › no keyboard shortcut for adjusting volume keyframes on clips in timeline???
  • no keyboard shortcut for adjusting volume keyframes on clips in timeline???
    Posted by Nicholas Natteau on January 10, 2015 at 1:25 am
    In Final Cut Pro 7, I remember that we could assign keyboard shortcuts for adjusting the gain levels of audio clips in the timeline.
    In Premiere Pro CC, there’s a keyboard shortcut for changing the volume level of the entire clip. But how about when you set multiple keyframes within the audio clips in the timeline, is there no keyboard shortcut that allows you to nudge the volume up and down for each keyframe set?
    This is a feature I used so often when adjusting the volume level of audio clips in FCP7. I’m surprised this keyboard shortcut feature isn’t available for such a widely used task as audio level adjustment to individual clips in the timeline.
    Peter Garaway replied 11 years, 8 months ago 3 Members · 2 Replies
  • Massimo Alberto croce
    January 10, 2015 at 12:22 pm
    “g” on the keyboard (if you have premiere pro default keyboard short cut) to adjust the gain of the clip in time line.
    Massimo Alberto Croce
    Video Editor, Colorist, Pro Tools Editor
    massimoalberto.croce@gmail.com
  • Peter Garaway
    January 11, 2015 at 11:50 pm
    Hi Nicholas,
    In the Keyboard short panel search for Nudge Volume. There you will find assignable shortcuts for nudging the volume 1 or 3 -/+DB.
    You can click and select multiple keyframes or drag and select and adjust all at the same time.
    Hope this help!
    Peter Garaway
    Adobe
    Premiere Pro
