Activity › Forums › VEGAS Pro › no key frame box on effectgs for sony vegas 8
  • no key frame box on effectgs for sony vegas 8
    Posted by Michael Gaylin on November 17, 2009 at 8:45 pm
    Hi…I’m cutting a project with multiple layers on Sony Vegas 8. I’m using track effects on some of the tracks. But for some reason when I want to apply effects to individual events the key frame box is not showing up. So I can’t animate the effects. These are effects that I know ordinarily allow key framing. Does anyone have an idea about what could be going on? Thanks in advance…
    Mike
    John Gleason replied 16 years, 10 months ago 3 Members · 4 Replies
  • John Gleason
    November 17, 2009 at 9:55 pm
    Sometimes the keyframe box gets dragged “into” the bottom and becomes hidden. If this is what happened to you just scroll your mouse on the bottom of that particular window until a double up-and-down cursor appears and then drag the keyframe box up. It is kind of like when your taskbar drops below your HUD and you have to go fishing with your mouse.
  • Theo Van laar
    November 17, 2009 at 10:26 pm
  • Michael Gaylin
    November 17, 2009 at 10:45 pm
    Thanks so much. That was driving me crazy for a while. Don’t know how I buried the key frame box but I have it back now! Appreciate your help.
  • John Gleason
    November 18, 2009 at 8:03 am
    Glad it was as simple as that. It seems if you use Vegas long enough it eventually happens to you. I usually just attribute these kind of problems to the well documented issue of sneaky Mackintosh Gnomes.
