Activity Forums Apple Final Cut Pro Legacy No insert editing with Firewire?
  • No insert editing with Firewire?
    Posted by Mark Arenz on September 29, 2005 at 3:54 pm
    I’ve noticed this a few times. I’m mastering a show via Firewire (I usually go out SDI) and notice that my only option is to assemble edit onto the tape. That’s fine for spot work, but as I’m getting ready to make a 5 second edit in a 2 hour show, this is becoming a real issue. My client is going to balk at the notion of paying for 2 hours of work because of what appears to be a deficiency in the software (though I would guess that it has something to do with the deck or the Firewire spec).
    It’s a Sony DV-CAM DSR-1500. I’ve noticed this on DVC-PRO 50 editing as well, even if I’m going out SDI. What gives?
    Kevin Monahan replied 20 years, 12 months ago 3 Members · 4 Replies
  • Jeff Carpenter
    September 29, 2005 at 5:00 pm
    Yup, it’s firewire. It doesn’t have the ability to do insert editing.
    As for your trouble with SDI, that’s something to do with the deck, I guess. I don’t really know there, but when it comes to firewire then it’s the firewire that’s the problem.
  • Kevin Monahan
    September 29, 2005 at 7:09 pm
    The Sony DSR-1500 has a RS-422 port. You can insert with RS-422. Just get a cable and a serial port adapter and you’re in business.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
  • Mark Arenz
    September 29, 2005 at 10:46 pm
    Thanks for the advice. I tried going out firewire and controlling via 9-pin and it only resulted in a half dozen restarts and a stream of profanity.
    I managed to kick out those new shots in D1 via SDI. There’s a slight difference but since they’re cuts it can stay my secret.
  • Kevin Monahan
    September 29, 2005 at 10:59 pm
    [Mark Arenz] “I tried going out firewire and controlling via 9-pin and it only resulted in a half dozen restarts and a stream of profanity.”
    Hmm….that’s odd and should not be happening.
    Kevin Monahan
    fcpworld.com
