Activity › Forums › Blackmagic Design › no input signal Decklink HD
  • no input signal Decklink HD
    Posted by Bbfilmsguy on March 13, 2006 at 9:45 am
    I can capture from DigiBeta no problem-switch to HD (JH3) switch all settings-go to capture-“no video input” comes up-I have deck control-double checked settings inputs and prefs-whats up?
    s
    Bert replied 20 years, 6 months ago 2 Members · 1 Reply
  • Bert
    March 13, 2006 at 2:59 pm
    1- check that the fcp settings match those of the jH3 (25psf to 50i //29,97psf to 29,97 ..)
    don’t forget to match the deck-control with these settings.
    2- if the tape inserted into your jH3 is playing without a flashing frame-rate indicator, then your setting of the JH3 is correct.
    3- check in the Apple sys. pref. >> blackmagic the HD up/downconvert input should be OFF.
    4- enjoy HD editing …
    http://www.2frame.be
