Activity Forums AJA Video Systems No immediate monitorredraw while colorcorrecting in FCP
  • No immediate monitorredraw while colorcorrecting in FCP
    Posted by Sven Giebel on June 11, 2009 at 6:03 pm
    maybe you can help me on this one:
    when I’m using the 3way colorcorrection effect I usually activate the effect via a shortcut and start correcting in the effectwindow. I see the changes immediately in the canvaswindow but not on the big panasonicdisplay which is hooked up on our second LHe SDI-output. I have to click into the canvaswindow to force a redraw on the panasonicdisplay (where I have activated the build-in waveformdisplay). Not only is this pretty annoying over the day, it’s also risky, as it already happened to me that I changed the clip position without immediately noticing it.
    Is there a better way to do this? Are there any settings I’ve overlooked?
    Sven
    Matt Larson replied 17 years, 2 months ago 2 Members · 1 Reply
  • Matt Larson
    June 24, 2009 at 4:24 pm
    Pull the Color correction tab out to a seperate window on your screen (so you can see the CC wheels and the Viewer window) Then you will get real-time feedback on your external monitor
    2 x3Ghz Quad MacPro
    9 GB RAM
    Mac OS X 10.5.5
    QT 7.5.5
    FCP 6.0.5
    AJA Kona 3 (6.0.1 drivers)
    G-Speed XL 12 RAID
