Activity Forums Adobe After Effects No Image….twixor 4.5-fcp 6.0.5
  • Vinnie Urgo
    August 3, 2011 at 6:05 pm
    Certaintly the way to properly use the footage at 60p. However When I twixtor it there is about a 12 frame pause in the motion of the image about every 10 frames. Tried a few different settings but same result…
    Vinnie Urgo
    Photo and Video Professional
    vincenturgo@gmail.com
  • Pierre Jasmin
    August 3, 2011 at 6:24 pm
    That’s a sign of your clip FPS in being less then FCP project out (29.97 versus 30 will do a frame repeat once in a while but early in a sequence)… maybe send a project with a short clip that demo the problem to techsupport @ revisionfx dot com so we see in context
    Pierre
  • Peter Litwinowicz
    August 3, 2011 at 6:38 pm
    Also wondering, has FCP imported the footage as interlaced when in fact it is progressive?
    make sure to view the item properties for the clip (in both the bin and timeline) and see if FCP has incorrectly marked the footage “Field DOminance” property.
    Pete
Page 2 of 2
