Activity Forums Adobe Premiere Pro No image with Capture
  • No image with Capture
    Posted by Scottsdigitalphoto on May 24, 2006 at 2:48 pm
    All preferences are properly set for the DV. The buttons work, but the image will not come up.
    I can use NERO to capture the files, but not Premier.
    Using a PC dual core AMD’s with two raptors.
    Thanks of any help.
    Scott
    Richard Evans replied 20 years, 4 months ago 3 Members · 4 Replies
  • Aanarav Sareen
    May 24, 2006 at 4:36 pm
    Capture deck? Does the capture window come up as blue or black?
    Aanarav Sareen
    premiere@asvideoproductions.com
  • Scottsdigitalphoto
    May 24, 2006 at 8:28 pm
    It comes up black and I get the Device message “Cnat activate Recoder – try resetting the the camera” Turning the camera on and off does not affect the capture deck.
    Everthing works fine with Nero, but I need to use Premier.
    May 25, 2006 at 2:23 pm
    I still need input on this.
    Any help appreciated.
    Thanks.
  • Richard Evans
    May 25, 2006 at 4:05 pm
    First off, what equipment are you using? What type of camera; brand and model. Are you hooking up via firewire? What are your device settings in premiere set to? Give some details and I’m sure somebody can help out.
    Richard
