Activity › Forums › Sony Cameras › “No Image” when trying to import clips using XD cam transfer
Don Greening replied 15 years, 6 months ago 11 Members · 23 Replies
Michael Palmer
January 27, 2008 at 12:14 amCraig ,
My bad on the Intel needs. Don’t know what I was thinking. I guess I tried loading the Clip Browser on my G4 Power Book that didn’t work, and was thinking about the XD Cam Transfer program. I was wrong for this statement.Michael Palmer
Good Luck
Michael Palmer -
Steve Wargo
February 7, 2008 at 9:05 pmWe just got FCP 6.0 yesterday, installed it and no images. Did the 6.2 thing and everything works fine. I’ve shot 4 jobs up to this point and we’ve been holding our breath till today.
Life is good.
Steve Wargo
Tempe, Arizona
It’s a dry heat!Sony HDCAM F-900 & HDW-2000/1 deck
5 Final Cut (not quite PRO) systems
Sony HVR-M25 HDV deck
2-Sony EX-1. -
Sean Fawcett
June 27, 2008 at 3:08 amI also do not have an Intel Mac. When I looked for “Sony Transfer Tool” I only got links to the XDCAM Transfer Software, which doesn’t work on non Intel Macs. Do you know of any links to download the Sony Transfer Tool or is there a more precise name of the software? Thanks.
Craig Seeman
June 27, 2008 at 12:30 pmXDCAM Transfer tool DOES WORK ON NON INTEL MACS. I have it running on G5 Mac.
Only Clip Browser doesn’t run on PPC Macs
Danielle Tinker
July 8, 2008 at 10:26 amHi Don (or anyone who can help)
I have encountered a unique problem that I have never seen before. Half of my clips are fine, the other half display the hated message of “no image available,” Just as Sarah encountered. I have been using the EX for at least a month and haven’t had any problems.
I have Quicktime 7.5 (149.5)
Final Cut Pro 6.0.4 with all the codecs
Mac OSX 10.5.4The clips are long: it was a conference where I continuously recorded and downloaded on the day.
Any thoughts?
Danielle
Olaf Steel
May 26, 2010 at 11:37 amI’ve had the same thing. I copied the BPAVs to my computer and when I try to view them in XDCAM Transfer, I can’t see them all. I get the ‘No Image Available’ message in a gray window where the video should be.
However I can view the files if I play them in VLC media player.Has anyone found a solution to this?
Olaf
Rafael Amador
May 26, 2010 at 12:08 pmPut the BPAV folder inside another folder and “Add’ this one in the Transfer tool.
rafael -
Olaf Steel
May 26, 2010 at 4:06 pmThanks for the help.
I have the BPAVs in another folder. Some of the files will show up in XDCAM Transfer, some of them appear blank. I can see all the info related to teh clip, its duration, size, etc but cant play it.
I have shot 4 films using the EX1 and always used the same method to bring the files into FCP. This is the first time I’ve had an error, and have no idea how this is happening since nothing has been changed since the last time it worked.
If anyone has any more help, I would be very appreciative.
Olaf
Rafael Amador
May 26, 2010 at 4:12 pm[olaf steel] “Some of the files will show up in XDCAM Transfer, some of them appear blank. “
You haven’t said that before.
that sounds to files corruption (too fast stop/rec?).
The only way to know if the files are valid or not is to use the Clip Browser as I told you before.
If the Clip Browser do not accept the files, but they are playable with VLC, your only option to recover the files, I think, is treasured.
rafael -
Olaf Steel
May 26, 2010 at 4:14 pmThanks for your reply Rafael,
What do you mean by “your only option to recover the files, I think, is treasured”?
Is there a way to recover the files?
Olaf
