Activity › Forums › Boris FX Particle Illusion › No Image is shown in the particleView
Posted by Oliverschramm on October 17, 2007 at 6:24 pmHi @ all,
first thanks to Alan and all the others for the great update of my most favourite software !!!
Only one problem:
In the new particleView i canOliverschramm replied 18 years, 10 months ago 4 Members · 6 Replies -
John Holste
October 17, 2007 at 9:26 pmOli,
there is supposed to be a file “image.raw” in the application folder. I am quite sure it was not in the install, update or full. We will have to hope Alan will bail us out and provide a link.
John
Alan Lorence
October 17, 2007 at 9:34 pmHere is the link. Unzip into your pI3 folder (where the particleView.exe is).
https://www.wondertouch.com/downloads/pview_image.zip
Alan.
Ra-ey Saleh
October 19, 2007 at 3:18 amWeird. Unzipped file into pI folder and still no image appears.
Alan Lorence
October 19, 2007 at 11:16 amDepends how you launch particleView. If you browse to the particleIllusion 3 folder and double-click the pView exe there, the image display will work. If you use a desktop shortcut (or Start menu, or Quicklaunch) it won’t.
The reason is we didn’t fill in the “Start in:” property of the shortcuts.
To fix this, r-click on the shortcut (whether it’s on the desktop, in the Start menu, or in the quicklaunch bar) and select “Properties”. Then change the “Start in” box to point to the folder where particleView.exe is located. You can copy and paste this from the “Target:” box above, but you have to remove the “particleView.exe” part.
So on my system, I have:
Target: “C:\Program Files\particleIllusion_3\particleView.exe”
So I need to make “Start in” look like:
Start in: “C:\Program Files\particleIllusion_3”
Notice that the quotes are required if the path has any spaces in it. Also, there is no ending slash on the “Start in:” path.
Alan.
