Activity › Forums › Adobe Encore DVD › No Highlights on Encore CS3 for Mac?
  • No Highlights on Encore CS3 for Mac?
    Posted by David Eves on July 23, 2011 at 2:26 am
    I was recently using Encore for the first time on my 2010 iMac and ran into a bit of a jam. When making any sort of menu, the menu highlights don’t always seem to show up on the DVD. I can see the menu highlights just fine when the disc is being played on a computer or a bluray player, but when in a regular old fashioned DVD player, I get a unnavigable menu. Anyone else seem to encounter this problem, and if so, does anyone have a solution?
    David Eves replied 15 years, 2 months ago 2 Members · 2 Replies
  • Jon Geddes
    July 24, 2011 at 9:38 pm
    This is a well documented problem with Encore and the Mac OS. What you need to do is edit the menu in Photoshop, and change the highlight layer prefix from (=1) to (=3). Then in Encore, you may need to change the color of the (=3) highlight colors in the menu color set.
    Jon Geddes
    http://www.precomposed.com
  • David Eves
    July 27, 2011 at 8:16 pm
    Changing the prefix from (=1) to (=3) worked like a charm. Thank you thank you THANK YOU.
