Activity › Forums › Adobe After Effects › No Help info
  • No Help info
    Posted by Chris Carpenter on September 22, 2008 at 3:54 pm
    CS3 AE
    When you goto Help-> After Effects Help
    nothing pops up. When I put anything into the “search” field it goes to generic apple use issues.
    Yes, After Effects is open and running without issue, but I have techs who refer to the Help function all the time.
    Help me find the Help.
    Chris Carpenter replied 18 years ago 2 Members · 2 Replies
  • Chris Wright
    September 22, 2008 at 6:09 pm
    If you can’t open this software program, it needs to be re-installed. You can open in from start->run then select AE as search param and enter search query.
    C:\Program Files\Adobe\Adobe Help Viewer\1.1\ahv.exe
  • Chris Carpenter
    September 22, 2008 at 6:32 pm
    I should have mentioned I’m on a Mac. I don’t see what you are referring to.
    Chris
