No firewire output on Kona LS
I just got a Kona LS fully updated (v.1.1.3) on a G5 dual 2.0 running OS 10.4.2…I have been running everything on the AJA 10bit Uncompressed codec until now and it has run perfectly. I have redigitized everything in DV NTSC and am working ‘offline’ on a DV project/timeline. For some reason my firewire is acting up and it won’t output the DV signal to my deck. I tried refreshing the external devices, but this seems to only result in glitchy video and then it eventually cuts out. My external video is set to ‘all frames.’ Any ideas? Can I view external video thru the Kona card while working in DV?
