Activity › Forums › Adobe After Effects › No Extrude parameter in Graphic Options…Illustrator file (vector image) layer set to 3D
  • Roland R. kahlenberg
    December 17, 2013 at 12:43 am
    Your comp renderer has to be set to Ray-tracing. You set the renderer in your Comp’s Advanced Tab.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
  • Matt Orfalea
    December 17, 2013 at 1:23 am
    Already set to Ray-traced 3D. Any other ideas?
    Any help greatly appreciated!
    Matt
    https://www.youtube.com/orf
  • Matt Orfalea
    December 17, 2013 at 1:46 am
    I needed to right click and make it a shape layer. So I do that and now I get “error outline contains triangles that are too small to be rendered check for very thin triangles and original artwork”… :/
    Matt
  • Matt Orfalea
    December 17, 2013 at 3:02 am
    I saved it as an EPS and it solved the problem.
    https://forums.adobe.com/message/4739516
    Matt
